Battery dying and won’t idle unless warmed up
Old Jun 27, 2019 | 03:42 PM
Matthew Harris's Avatar
Matthew Harris
Default Battery Dying. Bad Idle
Hey guys I’m new here. Having weird issues. My truck battery dies after sitting for a day. If i can get it started after a couple tries it won’t idle unless i get the rpms up. Runs fine once it’s warm. If it’s jumped by a pack it runs fine immediately. Battery tested good. Alternator failed test. Changed it and still having issues.
99 Dodge Ram 1500 Sport 5.9L
Old Jun 27, 2019 | 04:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Probably the voltage regulator in the PCM you can wire an external one into the truck
Old Jun 28, 2019 | 09:51 AM
Moparite's Avatar
Moparite
Did you check the alternator fuse in the engine compartment box?
