daylight running lights
Old Dec 15, 2005 | 12:34 AM
rustyram's Avatar
rustyram
Default daylight running lights
hi everyone,i have a 2001 ram quad cab with a 5.9 l,I am having a problem with the drl staying on adfter the truck is off,unhooked the wire from the drl module,and the lights stay off,after about 2 weeks,the lights stay on even when the light switch is off and the truck is offf,I have to disconnect the battery cable too get the drl off,then reconnect the battery and the lights are fine til i turn them on again,then its back to disconnecting the battery to turn the drl off,not surewhy they would stay on again,we unhooked the module and it was fine for a few weeks,now back to the same problem,dont understand it,considering i have the drl module unplugged,did i unhook the wrong thing,couldnt have it solved the problem for a few weeks,the module is under the hood on the drivers side close to the firewall,is this correct,any help would be very appreciated thanks guys
