New Battery Gauge Reading
Old Aug 23, 2019 | 02:25 PM
VirgilDoc's Avatar
VirgilDoc
Default New Battery Gauge Reading
Good Morning
Just put in new Everlast Maxx 27 battery on 1998 Ram and the reading on the gauge is about 10 so can someone tell me if there is a problem and what to do? Thank you.
Old Aug 23, 2019 | 02:55 PM
renardk764's Avatar
renardk764
Alternator or Voltage Regulator (which is a part of the computer) Voltage should be about 14 volts (14.3 is what I've read). With the truck running, measure the voltage across the positive and negative with a meter. should be 14.3 ish at idle.
Have the local autozone/advance auto/oreilly autoparts test alternator. they can do it on the truck.
Old Aug 23, 2019 | 03:04 PM
VirgilDoc's Avatar
VirgilDoc
thank you
Old Aug 23, 2019 | 03:32 PM
renardk764's Avatar
renardk764
Hey VirgilDoc, if it ends up being the voltage regulator, google dodge ram external voltage regulator mod. It's much cheaper than finding a replacement computer. Just did mine and can give you some tips if needed.
Old Aug 24, 2019 | 09:19 AM
Moparite's Avatar
Moparite
Check the voltage of the "new" battery you are putting in. No telling how long it sat on the shelf! I had an issue with my ac compressor and jumped out the relay. It sat for two days and when i went to start it barley started. (coil was engaged ) The gauge was reading in the 10-12 range, After driving it a while it returned to 14 where it normally stays.
