Changing front shocks
Old Aug 26, 2019 | 01:22 PM
JD Untersee's Avatar
JD Untersee
Default Changing front shocks
I have a 1999 2nd gen dodge 2500 with the 8.0 and I was changing my shocks and got the passenger side done but when I went to do the driver side I noticed that the master cylinder was in the way from removing the shock completely, please help any advice would be greatly appreciated
Old Aug 26, 2019 | 01:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It's not in the way, just a little tight
Old Aug 26, 2019 | 04:31 PM
Jimythefan's Avatar
Jimythefan
Yep, very little wiggle room.
I'm not sure how you are going at it, but try removing the whole top mount with the shock as a unit and disassemble outside of the truck. The 3 mounting bolts are easier to get at. That method worked best for me.
Old Aug 26, 2019 | 07:45 PM
Torxhead's Avatar
Torxhead
Help me out guys, like just what is going on. As my shocks come out thru the bottom. Or is this a 4wd version?
Old Aug 26, 2019 | 08:38 PM
MoparFanatic21
On 4wd they come out through the engine bay by removing the 3 bolts holding the upper hat in
Old Aug 27, 2019 | 05:54 PM
Torxhead's Avatar
Torxhead
Thanks MoparFanatic, I just figured they would come out thru the bottom also,
Old Aug 27, 2019 | 06:25 PM
MoparFanatic21
They can, but depends on how bad they are
