High idle
Old Sep 7, 2019 | 10:28 PM
Johndrl's Avatar
Johndrl
Default High idle
Hi I have a 1998 ram 1500 4x4 5.9 gas and after replacing the tps and the iac valve I still have an idle at around 1600 rpm other than vacuum leaks is there anything that may cause this issue?
Old Sep 7, 2019 | 11:27 PM
Torxhead's Avatar
Torxhead
Worn out throttle shaft or stuck iac valve. I would think you would have some vacuum lines that have not been replaced though. Somehow extra air is entering the engine.
Old Sep 8, 2019 | 10:24 PM
2bit's Avatar
2bit
Try disconnecting the battery to reset the computer first. Also, what brand IAC and TPS?
