Tires too big?
Old Nov 9, 2019 | 07:47 PM
toddean's Avatar
toddean
Default Tires too big?
1995 Dodge Ram 1500 4wd 5.9L
I bopught this truck and it had 285/75R 16 tires on it. At first no problems, then a string of problems and error codes having to do with the VSS
mounted at the transfer case - replaced that; Cruise contriol stopped working and speedometer started bouncing around and then finally quit
altogether- went through everything and replaced everything - actual speedometer guage was last thing I replaced at $250.00. It works great except
when I'm going about 40 mph it reads 100-110 mph.
The tag inside the drivers door says truck came stock with tires that were 225/75R 16
Could this be the problem??
Could a new speedometer pinion with the correct amount of teeth for my tire size be an option?
Old Nov 9, 2019 | 10:05 PM
Eric Tharp's Avatar
Eric Tharp
I would. I changed my gear in tranny after I put 4.10s in my 97 ss/t
Old Nov 9, 2019 | 11:25 PM
Ramman18's Avatar
Ramman18
Tires aren't the problem but do make speedometer read off.
Old Nov 10, 2019 | 09:53 AM
Moparite's Avatar
Moparite
Yes but the speedo reading 100 at 40 is a problem that a gear change is not going to fix. I would pull out the whole vss assembly and take good look at it or it could be a faulty sensor.
Old Jan 2, 2020 | 11:37 AM
toddean's Avatar
toddean
I changed the vss twice. Also, the readings I get from testing the vss per the service manual check out good.
