New injectors??
Old Dec 2, 2019 | 08:44 PM
1974dodgeowner's Avatar
1974dodgeowner
Default New injectors??
I recently bought a 96 dodge 4x4 for 500 bucks. Body in good shape but engine was in the bed haha. After very little investingation I realized the kid had actually pulled the engine apart. then stuck it back together. No bearings, no rings etc etc. Decided I am not going to even try to rebuild on my own, Just took the mess to the local engine shop and basically said"Have fun!' I now have a fully rebuilt, machined ready to go short block that needs heads, discovered both my heads are cracked,. Going to buy the EQ heads in a month or two. He claims it ran when he pulled the engine. Makes ya wonder why he pulled the engine haha. All is well, but, I am thinking about just replacing the injectors. I know I can test them for the basics, but no idea how I would test their spray pattern. For all I know they are worn to the point that they just spray a stream instead of an atomized pattern. If that makes sense..Also replacing all the sensors on the engine. Because I really dunno what I have. What are your favorite replacement injectors? And sensor brands?
Old Dec 3, 2019 | 01:43 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Mopar or Standard Motor Products sensors but try for the Mopars
Old Dec 3, 2019 | 06:40 AM
Moparite's Avatar
Moparite
Delphi sensors, They are actually a supplier for the auto makers. You can send out the injectors or just buy new ones. They will match the flow output on them. Injectors outputs are slightly different to a degree and not matched from the factory.
https://www.injectorrx.com/fuel-inje...uel-injectors/
Old Dec 3, 2019 | 12:51 PM
1974dodgeowner
Awesome thanks for the replies.
