No start...no crank...no nothing. A story,not a problem.
Old Dec 28, 2019 | 02:46 PM
cj5orion's Avatar
cj5orion
Default No start...no crank...no nothing. A story,not a problem.
So...this morning I start the truck,nothing.
Tried jerkin the shift lever,pushing,pulling,rotating,(tried to rotate),the steering wheel...nothing.
No power anywhere,wipers,turn signals,fan.,no clicks..nothing...jus dead !
I knew I had cleaned the battery post and connetions not to long ago,checked battery volts...all good...???
So,spend about 2 hours on this forum looking up post,ignition switch,celonoid,ground connections,changing out the relay,etc.
Thinking about hot wiring it for a syptom check.Thinkin about the relay swap trick...
Went to disconnect batt cables...hmmm...a lil dirty..."might as well clean em again as long as I'm here","cant be the prob though,they werent that bad,and I just cleaned em a few months ago"
Well...sure as s#*t,that was the prob !!!
