Leveling kit
Old Jan 16, 2020 | 03:26 PM
mikeyshenk's Avatar
mikeyshenk
Default Leveling kit
If you put a leveling kit on your truck will you have to replace ball joint and wheel bearings often? Or once you put it in all you need is an adjustable trac bar
Old Jan 16, 2020 | 03:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No
No
No
Its easy and a cheap way of lifting your vehicle
Old Jan 16, 2020 | 04:17 PM
HeikIlm's Avatar
HeikIlm
You can get away with a stock track bar, if you don't mind the left tire poking out from the fender slightly.
Old Jan 16, 2020 | 07:28 PM
armynurse's Avatar
armynurse
I put 2" taller springs up front, and a 2" long-leaf add-a-leaf lift in the rear (and 33" tires). Has the factory length track bar. Looking at the front you can't tell if the tires are shifted to one side or not.
Old Jan 17, 2020 | 10:08 PM
armynurse's Avatar
armynurse
Before I put the 2" springs up front and the 2" lift add-a-leaf in the rear (see previous post), I put a 1.5" spring spacer up front as a "leveling kit". Afterwards, I noticed something; the back of the truck seemed lower. I had taken measurements before and after, and sure enough, the hitch was now lower after the front spring spacer than before (1-point-something inches - it was a long time ago). So I made about a 5/16" tall lift block out of some steel and bolted it to the spring pack using the spring center bolt, so it sat between the springs and the factory block. That brought the hitch back up to just a little more than before the front spacer. 5/16" higher at the axle (measured at the center of the rear wheel well), but by the time you measured at the hitch, it was almost two inches higher at the hitch.
All I can figure is... think of your truck as a see-saw. When you lift up just the front of the truck, it pivots on the rear axle. And like with a see-saw, when the front of the truck goes up, the back bumper ends up going down. Can you picture it?
Something to think about.
