Transmission Pan Missing Bolt/Stripped Thread
Old Jan 26, 2020 | 05:59 PM
Rasta9615004x4's Avatar
Rasta9615004x4
Default Transmission Pan Missing Bolt/Stripped Thread
Hey everyone,
96 1500 5.9 4x4 Automatic
1. I’m new to all this mechanic stuff and to dodge
2. I over torqued one of the bolts on my tranny pan and stripped the receiver threads, not the bolt. Didn’t realize til after the pan was already up in place with gasket sealant and every other bolt torqued. It was the last bolt that had the issue of course. I went and got all the stuff to retap the threads but I accidentally left all the stuff in my brothers truck and he left for the week. I need to get to work so could I fill it with fluid even though it’s missing a bolt? Would a single missing bolt cause it to leak badly? All the other ones are torqued to spec so I’m hoping it would hold for the week. Used RTV for the gasket and it has cured the 24hrs.
Thank you for the advice in advance.
Old Jan 26, 2020 | 07:26 PM
Torxhead's Avatar
Torxhead
You will have to find out the hard way as to weather it will leak or not. It just might work though, if it does you could insert a screw just larger than the bolt is. As for repairing it, you could insert a heli-coil to repair the threads or drill it out an tap a larger thread in its place. Be careful as not to do a redrill too deep. The internet is loaded with ways to fix stripped out threads:https://dsportmag.com/the-tech/three...maged-threads/
Old Jan 29, 2020 | 09:52 PM
Rasta9615004x4
I ended up having to helicoil the transmission flange and put on a new transmission oil pan. It leaked with the one missing but I also did my gasket wrong.
