Rear axle swap
Old Feb 17, 2020 | 08:22 PM
Kaleb Dwyer's Avatar
Kaleb Dwyer
Default Rear axle swap
Would a rear axle off a 99 dodge ram 1500 work on my 97 dodge ram 1500? Both are 355s
Old Feb 18, 2020 | 12:08 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yes it will.
Old Feb 18, 2020 | 06:37 AM
Kaleb Dwyer
Default Axle swap
Yes it will.
Thanks just checking didn't want any problems with driveshaft lengths and flange mounts. Or speed sensor.
Old Feb 18, 2020 | 12:12 PM
MoparFanatic21
Just use your old sensor everything else is the same. Driveshaft length doesn't matter because you are using yours. That only matters if you are trying to use all the parts from a different truck
