97 Ram 360 clicking noise
Old Feb 28, 2020 | 07:57 AM
Kaleb Dwyer's Avatar
Kaleb Dwyer
Default 97 Ram 360 clicking noise
My truck in drive makes this clicking noise that I can only hear sometimes even after its warmed up. If I put the truck in park it'll make the noise stop. I'm thinking it might be idle pulley maybe any ideas?
Old Feb 28, 2020 | 08:02 AM
HeikIlm's Avatar
HeikIlm
While driving, or even when you are standing still but transmission is in drive? 2wd or 4wd?
Old Feb 28, 2020 | 11:13 AM
Kaleb Dwyer
Default Clicking noise
Standing still but in drive like at a light or drive thru is when I usually can hear it. 4wd
Old Feb 28, 2020 | 11:48 AM
HeikIlm's Avatar
HeikIlm
Could be a lot of things, but you could start to locate sound by taking of the belt and running the engine. If the sound is gone, it's something on the belt drive. If not, maybe check the flexplate.
Old Feb 28, 2020 | 03:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Maybe exhaust leak or even the torque converter
Old Mar 2, 2020 | 11:37 AM
Kaleb Dwyer
Default Update
Changed my idle pulley and tensioner, noise still there although needed to change those anyway. Brand new exhuast on the truck and I had the trans rebuilt a year ago but maybe the converter is already bad or flexplate. Sounds like the clicking noise is coming from front of the trans by the oil drain bolt. Took a video of it, kinda hard to hear
Old Mar 2, 2020 | 12:25 PM
MoparFanatic21
I'm betting torque converter, torque converter bolts, or flex plate
