lean 360
Old Apr 8, 2020 | 10:41 PM
CommiCommander's Avatar
CommiCommander
Default lean 360
So finished up the NV4500 swap into the 1500, everything went well, except for the fact the truck has no power and if the engine is under load and below 2000rpm it will start violently shaking along with a flashing CEL, has misfire codes for every cylinder. Any help much appreciated
Old Apr 9, 2020 | 05:57 AM
Moparite's Avatar
Moparite
If the cap-rotor plugs and wires are good it's time to address the plenum issue.
http://www.hughesengines.com/Index/p...p?partid=27091
Old Apr 9, 2020 | 12:14 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Also could be a failing fuel pump
Old Apr 10, 2020 | 12:13 AM
CommiCommander
How would i check the fuel pump? And i am doing the Plenum fix this coming up weekend.
Old Apr 10, 2020 | 12:17 AM
MoparFanatic21
Fuel pressure gauge. Should be at least 45 psi
