Can't find brake controller factory harness(99 Dodge Ram 1500 4x4 5.9)
Old Apr 9, 2020 | 08:40 PM
SilentzHero's Avatar
SilentzHero
Default Can't find brake controller factory harness(99 Dodge Ram 1500 4x4 5.9)
So in all these videos I'm seeing that the factory harness for brake controller is a 4 pin blue connector
all I have is this black one that's attached to the dash
Update: after messing with the wires down there my truck won't crank.
Touched a wire from my battery to the starter connector and it started right up
Gotta love my Dodge
Old Apr 9, 2020 | 08:46 PM
primem's Avatar
primem
https://www.rockauto.com/en/catalog/...onnector,15581
here is what the plug in should connect to
Old Apr 10, 2020 | 09:58 AM
Moparite's Avatar
Moparite
That is IF you have the factory tow package, If not you have to wire it up yourself.
Old Apr 10, 2020 | 10:22 AM
SilentzHero
Well **** how do I do that
Old Apr 11, 2020 | 07:51 AM
Moparite's Avatar
Moparite
The factory tapped into the brake switch so it would work with the brake controller. You need to do the same and add the power cables and a wire running back to the connector for the trailer(brake). Yes it's a pita!
Old Apr 11, 2020 | 01:09 PM
DerTruck's Avatar
DerTruck
On my 2001 2500 the connector is in a somewhat hidden spot behind the wiring bundle from the large white connector. I had to remove the white plug to get to it. The truck did not come with a factory tow package either, the wiring ended at the connector under the left rear cab corner... doh.
