Looking into buying a set of used air bags off this guy online. There off a 2500 second gen.
I have a 96 half ton. will the mounts still work the same that come with it? Has anyone done this before from pulling something off at the junkers?
Thank you
If the 2500 is a 96-97 it will work. You only have one airbag on the steering wheel
