2nd gen AC wiring issue
Old Jul 6, 2020 | 05:01 PM
Chayce Jones's Avatar
Chayce Jones
Default 2nd gen AC wiring issue
I have a 2001 dodge ram 1500 5.9, 4x4, sport. AC is not working. Swapped compressor to see if a different compressor and clutch would work, but no fix. So I decided to check fuses and relays. Relay is good. Blowing fuses in box under hood. Where should I look next?
Old Jul 6, 2020 | 05:43 PM
Spillage's Avatar
Spillage
How’s the system pressure?
if the pressure is good, the low pressure switch is likely no good... not an uncommon issue.
Old Jul 7, 2020 | 08:49 AM
racerxv6's Avatar
racerxv6
I would check the harness going to the A/C and make sure that it is not grounding out any where....
