i hate rats part 2
Old Dec 21, 2005 | 01:10 PM
pirranah's Avatar
pirranah
Default i hate rats part 2
ok i replaced the plug wires. when i was putting one on the cap i noticed one was off the cap. if i got the two crossed would the truck still run? because i think i plugged them in the wrong spot. also what is the plug wire diagram for the cap. when i start it, it idles fine , but when i get to about 50mph it shakes really bad around 1500rpm when i'm giving it gas to get up a hill or something. the #8 cylinder missfire is still showing up, but i haven't cleared the computer since i replaced the wires so i think it is still in its memory
Old Dec 21, 2005 | 04:49 PM
V10's Avatar
V10
Default RE: i hate rats part 2
18436572
Dodge4x4810's Avatar
Dodge4x4810
Does you truck shake/vibrate when it is idling? Check for a burnt valve.
Old Dec 21, 2005 | 05:24 PM
pirranah's Avatar
pirranah
nope it idles smooth. it just shakes when i give it gas to move. i let it warm up to running temp and it still does it.
Old Dec 22, 2005 | 12:26 AM
grandmazer's Avatar
grandmazer
Before doing any of this clear your code and see if it comes back as missfire on #8. If it comes back I would start off by checking to see if I was getting spark to #8. If I was getting spark I would then check to see if I was getting a injector pulse at the #8 injector. If that checked ok I would then do a compression test. If that also checks ok and I knoticed the plug was dry while I was checking spark I would prob. condem the injector. . By the way as said before Firing order 18436572. I know this is aolt of if's but you have to eliminate possible causes 1 at a time. .I know some people would approach this a little differently but this I how I would attempt to diagnose it. Good luck.
Old Dec 22, 2005 | 02:33 PM
pirranah's Avatar
pirranah
thanks for the info
