Oil Pressure Gauge Issue
Old Jul 16, 2020 | 09:42 PM
Monkeyman23's Avatar
Monkeyman23
Default Oil Pressure Gauge Issue
2001 Ram 1500 w/318 (5.2 L)
Went through hell and back to get this thing going, changed engine spark plugs ignition coil crankshaft sensor, replaced oil did all that jazz
Me being a complete monkey decided to go ahead and floor the damn thing thinking things would open up and all of a sudden the pressure gauge drops to 0 and I get the check gauges light
Just wondering what my next steps are, I didn't cheap out on oil it was synthetic with the synthetic fram filter and barely drove 2-3000km
Any help is appreciated, new to the dodge community but I love my ****ty ram with half a dashboard
Old Jul 16, 2020 | 10:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
First thing I would do is hook up a mechanical gauge and see what that says. I will say my Durango did that and it was the Plenum.
Old Jul 16, 2020 | 11:26 PM
Monkeyman23
Default **Update**
When I popped the hood I found my air intake out of position (long neck was dislodged from air box completely and half in the fender) but oil levels were okay nothing seemed out of the ordinary
Driving it after 2 hours I found that when I floor it (truck lets me redline in first and second gear which scares me) the oil pressure gauge starts working again
Wondering if that's still a symptom of a plenum leak?
Old Jul 17, 2020 | 12:01 AM
MoparFanatic21
First thing I would do (I hate throwing parts at a vehicle) is hook up a mechanical gauge (can rent from part store) and take it to the windshield and floor it. If it still does it, then you have a problem. It could be a bad oil pressure switch
Old Jul 17, 2020 | 11:20 PM
dodgedakota98luver's Avatar
dodgedakota98luver
You need to hook up a manual gauge and check it. These trucks don’t have real gauges it is an idiot light disguised as a gauge. It’s possible you have very little oil pressure and when you rev it the oil pressure gets high enough to make the gauge pop up and work.
Old Jul 18, 2020 | 09:52 AM
Moparite's Avatar
Moparite
Might also be an issue with the gauges. Have you done the gauge test?
