Coil pack wiggly wire p0351
Old Aug 5, 2020 | 07:34 PM
Packwood Digital's Avatar
Packwood Digital
Default Coil pack wiggly wire p0351
Hey all
as some of you may know my coil pack bracket broke the other day and I had to fix it.
all was fine again until today it threw a p0351 code while idling. No misfire felt or anything out of the ordinary
but upon looking at my coil pack the top wire that leads to my distributor is extremely loose feeling is this normal?
ive included a video.
(ps i know the positive and negative wires shouldn’t be exposed like that and I am currently crimping new ends and doing them properly) the previous owner who installed it wasn’t exactly a mechanic...
should the top wire be this loose?
Old Aug 5, 2020 | 08:52 PM
DerTruck's Avatar
DerTruck
I don't think so. Maybe something broke when the coil was bouncing around.
Old Aug 5, 2020 | 09:10 PM
Packwood Digital
Im inclined to think you are correct I just don’t have another one to test the proper amount of play. I can always just buy a new one it’s only like $50 but I’ll be annoyed if that’s not it.
i re crimped the wires and soldered them properly and cleared the code. Gonna run it for a few days and see if it happens again.
Old Aug 6, 2020 | 06:28 AM
Moparite's Avatar
Moparite
That red thing looks like an adapter, The stock coil has a male terminal where that coil is female. May need replacing.
Old Aug 6, 2020 | 07:44 AM
Packwood Digital
yea it’s an aftermarket MSD part I don’t have a ton of experience with
Old Aug 15, 2020 | 08:46 PM
Packwood Digital
Update time!
i found the manual for my coil pack (blaster 2)
you take off the coil wire boot and where the nipple is you turn it clockwise which expands the inside coil contact and makes it really snug it’s no longer loose at all.
just wanted to share
