Empty catalytic converter
Old Sep 27, 2020 | 06:47 PM
Robinson98's Avatar
Robinson98
Default Empty catalytic converter
So I've had my truck for over a year now and just got a P0420 like a month ago. Got a buddy and some beers and decided to chop it off and see if I couldn't just gut it, but when I got it off the ****er was empty. Why did I just get the code now and will there be any issues if I don't replace it?
Old Sep 27, 2020 | 07:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The sensor may need a non fouler but no the code doesn't affect ATF ratio that's the front one. So you could leave it
Old Sep 27, 2020 | 07:47 PM
Robinson98's Avatar
Robinson98
appreciate it, was really hoping it wasn't anything bad
Old Sep 27, 2020 | 07:54 PM
MoparFanatic21
Yeah it's not bad a cheap way to check is some people had luck just putting the sensor on the frame
Old Sep 29, 2020 | 10:28 AM
Mike Holmen's Avatar
Mike Holmen
I had the same code when I deleted my cat, mine was plugged up solid. I welded up a straight pipe 3in delete pipe (I even cut out and weld in the old O2 sensor bung). I got two Dorman 42009 Spark Plug Non-Foulers (they will thread into the O2 bung) and some stainless wool, no more code.
Old Sep 29, 2020 | 10:42 AM
Robinson98's Avatar
Robinson98
Hell yea appreciate it, was tired of looking at that dam light
