Photo of location of the brake controller connector under the dash
Old Oct 26, 2020 | 10:28 AM
AtomicDog's Avatar
AtomicDog
I'll try to get a picture of mine on my 96
Thanks. That would be very helpful.
Old Oct 26, 2020 | 01:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Soi got two pictures. What's weird is it's white on my 96 but blue on my 01s and the others so maybe 98 and up is blue. I might have found a trick, go to where the wires come into the cab and the 4 wires should be by themselves, not in the loom. I took a picture of that too for you!
Old Oct 26, 2020 | 05:30 PM
AtomicDog's Avatar
AtomicDog
Found it! Thanks a lot for the more specific photo for the '96 model year. Mine is also white and the connector was very well hidden on top of and kinda behind the bulkhead connector. After looking at your photo and feeling around up there, I felt the empty plug jammed up against the firewall. As noted in the attached photo, mine is also white. I had no idea that it was as large a connector as it is, but its the right one, as it has a tow trailer label on it. I can now connect my trailer brake controller once I get the Dodge Ram specific wiring harness in the mail.
Old Oct 26, 2020 | 06:33 PM
MoparFanatic21
Glad you found it! It's hard to describe it's size as my "large" connector is the one with the bolt. I would consider it a small connector
Old Oct 27, 2020 | 01:03 AM
AtomicDog's Avatar
AtomicDog
I wouldn't call it a small connector, as it is pretty wide and has 4 very beefy terminals in it. That bulkhead connector is a monster sized connector for sure.
