Radio Doesnt work right with lights on
Old Nov 19, 2020 | 11:29 AM
KillerLemming's Avatar
KillerLemming
Default Radio Doesnt work right with lights on
Hello, On my 2002 2500 when i turn on my headlights my radio reception gets horrible. I have LEDS in the headlights and an aftermarket antenna, and the head unit is aftermarket. Could the LEDS or antenna be causing it or something else? Any input or ideas would be much appreciated. Thank you!
Old Nov 19, 2020 | 01:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Could be the antenna. Usually with aftermarket ones (especially if they are shorter) you will get crappier reception
Old Nov 19, 2020 | 11:33 PM
DerTruck's Avatar
DerTruck
Interference from LED lights isn't uncommon, does it sound like interference ?
Old Nov 20, 2020 | 08:17 AM
KillerLemming
Yes it does. I will see if taking them out helps
Old Nov 20, 2020 | 08:42 AM
jrsick's Avatar
jrsick
Copper foil shielding tape should fix you right up.
