Dies after starting (sometimes)
Old Dec 3, 2020 | 02:01 PM
armynurse's Avatar
armynurse
Default Dies after starting (sometimes)
Sometimes when starting the truck (96 1500 5.2 auto 4x4) as soon as it starts (in 1-2 seconds) it wants to die, or almost die. If I feather the gas for a few seconds before it dies it will keep running, and then it runs fine. And if you come to a stop when driving it, it acts just fine. It just happens when starting. New fuel pump just a couple years ago. Isn't my daily driver. Any ideas?
Old Dec 3, 2020 | 07:14 PM
Moparite's Avatar
Moparite
What condition is the battery in? How old?
Old Dec 4, 2020 | 10:54 PM
armynurse's Avatar
armynurse
Good question. Five-plus years? I'll have to check. Good point! And it has been getting chilly out here lately. Might be time for a new one. Would be nice if it were that simple.
Old Dec 5, 2020 | 08:40 AM
Moparite's Avatar
Moparite
5 years is usually the limit, Have it load tested i'm sure it will be in the weak zone(at best). Even if it's not you are on borrowed time.
Old Dec 5, 2020 | 07:50 PM
armynurse's Avatar
armynurse
I checked the battery. The little sticker says 12/18. So just two years old.
When checking out the battery, I noticed the negative cable could be moved easily by hand on the terminal. So I tightened it up. We'll see if that helps.
Old Dec 10, 2020 | 01:50 PM
armynurse's Avatar
armynurse
Yup; tightening up the ground cable clamp around the battery post seems to have fixed it. We're back to normal now. Cheap and easy fix!
