98 fuel line size
Old Dec 11, 2020 | 10:54 PM
Gregory P's Avatar
Gregory P
Default 98 fuel line size
1998 dodge ram 1500 what is the nylon fuel line size i want to make sure i can get it before i cut the line and remove a kink in the line, thks
Old Dec 12, 2020 | 07:52 AM
Moparite's Avatar
Moparite
Are you talking about the one from the fuel pump?
Old Dec 12, 2020 | 10:39 AM
AtomicDog's Avatar
AtomicDog
I had a similar issue with the short piece nylon fuel line that is on the long steel fuel line that goes from the fuel pump/tank against the frame to the front of the truck. My nylon fuel line kinked when I installed the new steel fuel line on my '96 Ram 2500 4x4 truck. I ended up cutting off the nylon line between the connector at the fuel pump and the steel fuel line and replaced it with some rubber fuel injection hose and fuel injection clamps. I looped the rubber line a bit to give me some slack if I ever needed to drop the fuel tank to replace the fuel pump in the future. So far, no leaks or issues with that repair.
Old Dec 12, 2020 | 11:14 AM
Gregory P's Avatar
Gregory P
the owner before me changed the fuel pump and must have kinked the line line in two spots, probably causing the pump to quit, but anyway the information i have found says its a 5/16 nylon line and i am thinking of just cutting out the kink and putting a dorman union were the kinks are
Old Dec 12, 2020 | 12:30 PM
AtomicDog's Avatar
AtomicDog
I believe I used 5/16" rubber fuel injection hose and clamps when I replaced the nylon line neat the tank. That nylon line kinks real easy in tight areas.
Old Dec 13, 2020 | 09:19 AM
Moparite's Avatar
Moparite
Not only that did you ever try to put on a new one? You are supposed to put the line in hot water to make it flexible before you try to install it. Well i put it in boiling water and still didn't work(kinked). I did the same thing AtomicDog did.
Old Dec 13, 2020 | 12:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I used a brake line flaring tool and it helped tremendously
