4X4 vacuum selector bypass
Old Dec 12, 2020 | 11:07 PM
Packwood Digital's Avatar
Packwood Digital
Correct! Not to mention you'll have 4wd faster as the cad doesn't have to engage. I got rid of my cad a while ago lol
whoaaaaa my mind is totally blown! I figured once I swapped the vacuum lines and got the 4WD light on the shifter became useless but I had it totally wrong!
Old Dec 12, 2020 | 11:50 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Nope! The cad just connects the axles. The transfer case actually transfers the power (hence the name). HeyYou explained it really well.
Old Dec 13, 2020 | 12:09 AM
Packwood Digital
I learn something new. Every. Single. Time. I come here
Old Dec 13, 2020 | 12:01 PM
MoparFanatic21
That's good
Old Dec 15, 2020 | 03:48 PM
Packwood Digital
Ok so another question. I always thought that when the front driveshaft doesn’t turn that means the 4x4 is engaged. (I realize this may be true “traditionally”) but in my application what is a definitive test to make sure 4WD is truly engaged or disengaged?
Old Dec 15, 2020 | 07:19 PM
MoparFanatic21
Get the back wheel stuck
Old Dec 15, 2020 | 07:33 PM
Packwood Digital
lol that’s one way I suppose
Old Dec 15, 2020 | 08:37 PM
MoparFanatic21
Unless you feel safe putting the whole truck on jack stands. Usually what I do is find a gravel parking lot and engage 4wd if it "jumps" it's in 4wd
Old Dec 15, 2020 | 10:19 PM
Packwood Digital
theres 4 inches of snow on the ground right now. I think I’ll block the back wheels and see if the front ones dig in/spin that should work no?
Old Dec 15, 2020 | 10:54 PM
MoparFanatic21
It should. I would try to get the truck "stuck" like for example my driveway has a little hill and if you stop on it with snow you need 4wd. That's how I test it.
