Coolant leak on 2001 dodge ram truck 1500
Subscribe
Dec 16, 2020 | 12:17 AM
Any one know why I would have a coolant leak coming out of the climate control condenser drain tube? It’s not much but I’m still loosing coolant slowly and I have none on the floor board in the truck it’s just coming out the a/c drain tube?
Reply 0
Dec 16, 2020 | 12:20 AM
That's just water from condensation like when you use AC then park it and it leaves a puddle. Someone smart put a hose on there which I did as well. If you're losing coolant (green) then you have a leak elsewhere.
Reply 1
Dec 16, 2020 | 12:24 AM
Quote: That's just water from condensation like when you use AC then park it and it leaves a puddle. Someone smart put a hose on there which I did as well. If you're losing coolant (green) then you have a leak elsewhere.
The ac to the truck doesn’t work never have since I’ve got the truck and it’s coming out gold/ orange color which I use a ZEREX G05® 50/50 Coolant
Reply 0
Dec 16, 2020 | 12:45 AM
Quote: The ac to the truck doesn’t work never have since I’ve got the truck and it’s coming out gold/ orange color which I use a ZEREX G05® 50/50 Coolant
Then most likely your heater core
Reply 0
Subscribe
