Double din bezel
Old Dec 24, 2020 | 08:26 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Tamuiel
They are upgraded from previous owner. Truck is white with 2008 20” wheels. Like new in and out with 200k miles. I installed a remote start/keyless entry, new shocks, tires, allighnment and courteousy leds all around including in bed. Will upgrade sound later
If you plan to upgrade the sound I recommend Kenwood as they are better for tuning. Alpine is the best but they are pricey
Old Dec 24, 2020 | 08:28 PM
Tamuiel's Avatar
Tamuiel
Yeah, i like both. Forgot to mention, it has cat back exhaust and headers. I put in a tuner to get rid of death flash. Would like to do locker too
Old Dec 24, 2020 | 08:32 PM
MoparFanatic21
For the rear there are no selectable lockers but the front there are a few options. I plan on putting a locker in my 2500 (ARB Air Lockers) just the parts are $2900 and I'm doing the labor myself
Old Dec 24, 2020 | 10:20 PM
Tamuiel's Avatar
Tamuiel
Nice. So i can’t get any kind of locking differential???
Old Dec 24, 2020 | 10:53 PM
MoparFanatic21
You can but you won't be able to select them. Which means they activate under throttle. So if you were going into a turn and punched the gas it would engage. Lol up videos for OX lockers it will explain it better
Old Dec 24, 2020 | 11:13 PM
Tamuiel's Avatar
Tamuiel
That’s what i want!!! When i do an occasional burn out or in the dirt
Old Dec 24, 2020 | 11:30 PM
MoparFanatic21
Then yes you can get them lol Eaton True Track is the most common. Technically they are just upgraded trak lol units.
Old Dec 24, 2020 | 11:46 PM
Tamuiel's Avatar
Tamuiel
Im not sure where to start or what to order. Im mechanically inclined, i know i can do the work. Just not sure what to get. Don’t want anything fancy, just both rear wheels to lock if i get on it or one wheel spins and not the other.. thanks for all your help
Old Dec 25, 2020 | 01:05 AM
MoparFanatic21
Rebuilding diffs are time consuming and there is no room for error. It can get expensive quick, good luck and you are welcome!
Old Dec 25, 2020 | 09:52 AM
Moparite's Avatar
Moparite
Truetrac is the best out there for a limited slip, Most of the factory units have clutches that wear out and stop working. The truetrac is a completely gear driven. I wouldn't install a locker unless extreme wheeling or drag racing and if that's all you plan on a spool would work. Factory limited slip would work and it's the most cost effective.
