2000 Dodge 1500 5.9 gas
Old Jan 20, 2021 | 11:05 AM
rtch1167's Avatar
rtch1167
Default 2000 Dodge 1500 5.9 gas
i am having an issue, where the truck wont drive faster then 40 mph or 60 kph and acceleration is slow.
i a new so if this has been discussed pleased ignore my lack of knowledge on previous posts.
thanks for all your help.
truck is all original with 244,000 km or 146,000 miles
360 gas
auto
4x4
regular cab, short box, sport model
truck idles fines and revs good, just when you drive, and the tranny seems suspect too
Old Jan 20, 2021 | 11:21 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
360 gas
auto
4x4
So you can red line the RPMs when idling if you rev it correct?
Old Jan 20, 2021 | 12:04 PM
true blue's Avatar
true blue
Does the exhaust sound like someone put an even bigger muffler on it or does it breathe free with a hollow rumble to it? If not it could be your cat is clogged. These Magnum's are known for the intake leak that puts excessive oil into the cylinders then on to the cat where it clogs like cholesterol in your arteries.
Old Jan 20, 2021 | 12:27 PM
rtch1167's Avatar
rtch1167
yes redline no issue....
no excessive smoke
good pressure on the tailpipes
Old Jan 20, 2021 | 12:28 PM
rtch1167's Avatar
rtch1167
a nice rumble
no hesitation
replaced both o2 sensors too
Old Jan 20, 2021 | 12:39 PM
MoparFanatic21
no excessive smoke
Then what I would do is start with a fuel pressure test if they turns out to be good (minimum of 48 psi and may have to take the GAUGE to with windshield and drive with it) then a compression and leak down test
Old Jan 20, 2021 | 02:10 PM
rtch1167's Avatar
rtch1167
will do thanks.....
