Heated Seat Wire Help
Old Mar 11, 2021 | 02:58 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Heated Seat Wire Help
Ok so I'm trying to wire in the heated seats like the factory did and my big dilemma is the driver's door ajar switch.
If you look at 8W-45-7 it shows the Door Switch going to Joint Connector #8 on pins 6,7, & 19 as TAN when if you look at 8W-63-5 6 & 7 should be ORANGE.
Now looking again at 8W45-7 it shows the Door Switch going into C203 pin 18. If you look at C203 on 8W80-18 on the Body Harness Side it shows pin 18 as TAN but on the I/P side it says on pin 18 " TN (EXCEPT MIDLINE/BASE). Is that where it goes to ORANGE? If so why isn't it shown on 8W-45-7?
I'm confused on how the Door Ajar Switch plays a part in the Premium CTM. Because it's not showing the Door Jamb Switch
Old Mar 11, 2021 | 02:58 PM
MoparFanatic21
I believe it just changes to orange in the junction block. Either way I'll have a write up for heated seats here soon.
