Replacing electric mirrors
Old Mar 16, 2021 | 05:52 PM
Robert Coffey's Avatar
Robert Coffey
Default Replacing electric mirrors
I am trying to replace my mirrors on my 1997 Dodge Ram 1500, I got a set of mirrors given to me off of a 2003 Dodge Durango, is there a way I can retro fit the 2003 mirrors onto my 1997 truck? I’ve seen wiring diagrams that the wires from the newer mirrors are up and left, common, defrost, day/night wires, and ground. My 1997 only has 3 wires, is there a way to hook up the new mirrors if it’s possible?
New mirror passenger
1997 power mirror wiring
New mirror driver
Old Mar 16, 2021 | 08:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Defrost you can't use. You could use all the other wires. The day/night is usually just a power wire.
Old Mar 16, 2021 | 09:14 PM
Robert Coffey
Default Heated mirrors
So I couldn’t just set up a relay and switch for the heated mirrors?
Old Mar 17, 2021 | 10:33 AM
MoparFanatic21
You could but it would have to be a timed relay. They heated mirrors only come on for about 15 minutes before they shut off. The factory switch was in the HVAC control which was 98-02 and won't fit 95-97. That's not saying you can just add a switch, but if you don't use a timer relay you'll burn the heated grid up.
