Battery Cable/Terminal Replacement
Old Jun 15, 2021 | 02:25 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I generally am bringing old equipment back to life. Often it is the older cloth covered wires. Fuse blocks are small and sort of an after thought on those. I wouldn't even try to use 2 gauge on a late model fuse box. 6 volt cables are thicker as they use half the voltage but have a lot more amperage. Look at some late model 12 volt cables and they are really thin compared to the 6 volt cables. I'm looking at a '47 Dodge right now and thinking of putting an 8 volt tractor battery in it and adjust the generator to 9 volts. That won't blow the lights but will really crank the starter.
If I were to make a wire to a late model fuse station, I'd probably go up one or two gauges.
I am going to upgrade my cables and open on replacing all the wires (even ones going to the fuse block) to at least 2 gauge.
Old Jun 15, 2021 | 04:32 PM
J D GA's Avatar
J D GA
Default Hot terminals
Edit: This reply of mine is not where it should be, can't delete it either. DodFor Web Master: Please change the Reply function to show reply below the post we're replying to, not to end of thread. It was like that once before. Thanks.
Last edited by J D GA; Jun 15, 2021 at 04:47 PM. Reason: ​​​​​​Reply didn't appear where I wanted it. Delete from this position
Old Jun 15, 2021 | 04:37 PM
J D GA's Avatar
J D GA
Originally Posted by Moparite
If you look up some battery terminals used for car stereo you can get any thing you would need.
https://www.amazon.com/Connectors-SU.../dp/B07QZRKXSL
Those are nice! I had no idea there was such a thing. Thanks for posting.
Old Jun 15, 2021 | 05:15 PM
ol' grouch's Avatar
ol' grouch
Over the years, I've gotten several vehicles where someone put a "system" in it. I try to avoid that as they tend to butcher the wires. On the other hand, I've salvage some high end hardware. Super heavy duty with gold plated connections. Almost NO amperage loss from end to end of a power line.
