My Dodge Ram no bus
I replaced cam Shaft position sensor and crankshaft position sensor checked all connections and when I turn the key on it says no bus but they’ll the difference is the little fuel light went off with the check engine light
"no bus" means no communication between the PCM and the cluster and because of that pretty much none of the lamps work (except high beam and turn signal indicators which are not controlled by the PCM).
Did the cluster work before changing the sensors ?
