Throw out bearing
Old Jan 3, 2006 | 02:16 AM
Koldkut's Avatar
Koldkut
Default RE: Throw out bearing
I posted up a thread asking for some help with that part and no one answered even after I bumped the thread with some info.....it made all my tranny problems dissapear....I had some rattling when I let it coast in 4th gear, I could feel some parts rubbing and now its gone...3rd gear would make some noise when coasting to a deceleration point, all that is gone now.....amazing what a $12 part can do.....keep in mind that is doesn't come in the clutch kit, you will need to get the part from the stealership and don't be suprised when they are suprised......its listed with the pilot bearing, won't show the part in their computer, but its listed when you list pilot bearings...
Old Jan 3, 2006 | 09:46 PM
BIGSEXY's Avatar
BIGSEXY
Mabee it that bearing making the noise insted of the throwout.....either way gotta go in[:@].Thanx again for the info..
Old May 1, 2006 | 08:30 PM
allamericanjeep's Avatar
allamericanjeep
whoa, wait a minute. are you saying the pilot bearing doesnt go in that hole? It has a sleeve that holds it??!!!?!
Im trying to get the bearing in the crank of my 360 (1999) and i have destroyed two! [:@][:@][:@]
can anyone explain where this sleeve goes and how i mount it?
thanks a ton!
Chris
(The guy putting the 5.9 in his jeep)
Old May 1, 2006 | 09:16 PM
jrmcx's Avatar
jrmcx
Any help here?
[IMG]local://upfiles/16276/F13A772534D54A3AA6772CD6693CE5B1.jpg[/IMG]
Old May 1, 2006 | 09:47 PM
allamericanjeep
thats what i followed to try to install this thing. I was beating it into the crank and it never budged. it did tear up the bearing though.
where does that sleeve go?
does the bearing get recessed in the small hole? or does the sleeve hold it in the large hole in front of the small hole?
sorry if that didnt make any sense
............. ___________
_______/
|...........1........2
|_______
.............|___________
thats my half assed text illustration of a side cut away of the crank. does the bearing sit inside the hole (1) or does that sleeve hold it in the larger opening (2)
Thanks
Chris
EDIT- added periods to make picture work. ignore them.
Old May 1, 2006 | 09:56 PM
allamericanjeep
the pic didnt come out right
Old May 3, 2006 | 05:24 PM
allamericanjeep
so i went and ordered the bearing and sleeve assembly. This makes sense now. in my little text picture it is on number "2"
fills up the entire hole in the crank.
i have pics if anyone wants em.
Chris
