2000 Ram 1500 5.2L 4x4 Larime Ticking issue
Old Aug 22, 2021 | 11:00 PM
Woodsbrandon96's Avatar
Woodsbrandon96
Default 2000 Ram 1500 5.2L 4x4 Larime Ticking issue
171k miles
I recently worked on the valve body (8k miles ago), the transmission is a 46re. I had to replace the tcc booster pin clip. ( I used a different part that replaced the clip.) And I installed a new 3-4 accumulator spring.
After turning off the vehicle a ticking noise would sound from the area underneath the steering wheel and behind the pedals. Ticks only after key has been shut off. When turning the key back on the ticking will stop. Also had a couple times now after startup the engine would die and I would have to crank it back up. My thought is possible fuel injector issue but I am definitely not someone who knows a lot. I can usually work on it but not troubleshoot that well. If anyone could help me figure out what it might be before I start tossing a lot of money at it that would be great.
Old Aug 23, 2021 | 03:44 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sounds maybe like a relay?
Old Aug 23, 2021 | 08:08 AM
Woodsbrandon96
Default Any idea on what relay?
Any idea what relay?
Also thanks for the advice.
I also forgot to mention that the passenger window failed to operate when either switch was used. Shutting off the vehicle and turning it back on allowed the window to be able to be used.
Old Aug 23, 2021 | 07:17 PM
MoparFanatic21
Sounds like a failing switch on the window.
Don't know about the relay, but that is roughly in the area you said you hear a clicking.
