Front bumper issues
Old Aug 31, 2021 | 02:28 PM
Dhalas818's Avatar
Dhalas818
Default Front bumper issues
Redoing my front end with Raptor coating, which is fantastic by the way, but I seem to have alignment issues. Bumper is level but the in and out look wonky as you can see by the photos. Is there also an adjustment for this? Also bought the bumper cover (green) and top fashia (black) used from a guy but don't match together correctly as you can see. Wondering if it's a knock-off North Korea part and I should of bought from LMT. Need some wisdom on getting it back aligned. Thanks guy's!
Old Aug 31, 2021 | 09:45 PM
AtomicDog's Avatar
AtomicDog
You should be able to adjust the bumper height by loosening the bumper at the frame, then jack up the bumper to the desired location with a floor jack and re-tighten the bumper bolts at the frame, then remove the floor jack. The top part of the cover looks like it isn't fully seated. I seem to recall that there are clips that hold it in place that may have broken when it was previously removed. You can check LMC truck's catalog to see if they carry the cover. Lastly, the headlights also don't appear to be properly seated and have gaps at the rear. When I used that style headlight on my truck, I had to cut out some metal behind the headlights to allow the headlight enough room to sit back properly. I had the same issue when I changed to the sport style 4 bulb headlights, but it was nothing my sawzall couldn't cure.
Old Sep 1, 2021 | 08:32 AM
Blayd's Avatar
Blayd
Yep. Headlights arent seated right for sure.
Some aftermarket light just dont fit right and you either have to hammer the back seat portion behind the light, or actually take metal out.
I found a set, ( not Halo or LED ) smoked, that fit exact. I liked them so much, I bought three sets, just in case.
as for the bumper, the top cover is definitely NOT seated all the way. Mine has a very small gap between the actual bumper, and the top cover. Need to see whats stopping it from seating. Maybe clips left behind from the old one you didnt notice?
I was working on mine for the past two weeks and took a look at mine.
