Magnum Partial Rebuild
Old Oct 14, 2021 | 12:15 AM
AtomicDog's Avatar
AtomicDog
Cam bearings are pretty easy to install if you have a cam bearing removal/install tool available to you. I'm sure you can find a YouTube video that shows the process.
Old Oct 14, 2021 | 12:48 AM
BClark_35's Avatar
BClark_35
Yea I just looked it up. Seems easy enough but for the cost of the tool I might as well have them professionally replaced. Only issue is moving the block again.
Old Oct 14, 2021 | 03:15 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I used a home made tool if you are invested in how I did it
Old Oct 14, 2021 | 09:11 AM
BClark_35's Avatar
BClark_35
Was it pretty simple to use? What was it made of?
Old Oct 14, 2021 | 01:43 PM
true blue's Avatar
true blue
Be careful of the idea of a quickie, when it comes to cam bearings. I made the mistake of inserting new cam bearings n not checking the fitment with the block. 500 miles later, WHOOPS, spun the bearing on an acceleration run. In the immortal words of yoda, the grammatically challenged repairman. Once again pull that engine you will, updated and hard learned will your experience be! YES!!!
Old Oct 15, 2021 | 12:57 AM
MoparFanatic21
Yep! I used a levee of all thread and a rubber expanding freeze plug. Worked like a charm. I got the idea off of YouTube
