Magnum Heads
Old Jan 1, 2022 | 01:57 AM
racerxv6's Avatar
racerxv6
how much was the Hellcat motor....?
Old Jan 1, 2022 | 11:29 AM
Moparite's Avatar
Moparite
If i was going to do that swap i would get a wrecked car and steel everything from it. You occasionally see them on copart. Like this one...
https://www.copart.com/lot/61485671/...-pa-harrisburg
Old Jan 1, 2022 | 11:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by racerxv6
how much was the hellcat motor....?
$20,000
Old Jan 5, 2022 | 09:31 PM
BClark_35's Avatar
BClark_35
If you are buying from a local shop, and you don't like 'em, at least you can go and talk to a real, live person about it...... That's the kind of insurance I like.
well a quick update on this. The heads came in. I found a casting number on the heads and it came up with engine quests website. So I'm assuming they are the engine quest heads. They were only $240 a pop but they are bare heads. No core return. Definitely seems worth it to me. The heads definitely look brand new as well. Definitely thicker between the valve seats as far as I can tell.
Old Jan 5, 2022 | 09:41 PM
BClark_35's Avatar
BClark_35
Originally Posted by Moparite
I'm trying to figure out why you buy heads that you don't know who makes them. I would stay away from ebay unless you know exactly what you are buying. I believe there is a thread here somewhere about aftermarket heads. And the problem with the EQ new castings(Odessa/Clearwate makes them). Have your machine shop check the heads real well! People buy the EQ's and they think they are ready to bolt on with the valves etc installed, But that's not the case. It says this on their site...
"Assembly of bare cylinder head casting should be done by qualified machine shop"
Because further machining needs to done IE the rocker post's need to be machined.
a
to answer your question, I went with what I could find for cheap. I could return the items if they did not check out after given to the machine shop.
