Replacing the tie rods and ball joints
Old Jan 23, 2022 | 07:49 PM
97Dodge5.2L's Avatar
97Dodge5.2L
Default Replacing the tie rods and ball joints
I bought the inner and outer tie rods from rock auto and the adjustment sleeves, are they different for the inner and outer?
Old Jan 23, 2022 | 08:02 PM
AtomicDog's Avatar
AtomicDog
I can't recall for sure, but if the RA part numbers you purchased are different for the inner vs. outer tie rod ends, then you have your answer.
Old Jan 23, 2022 | 11:51 PM
Ramman18's Avatar
Ramman18
Are the adjustment sleeves different from each other? I believe the stock ones are similar if not the same. The T steering are definitely different sizes from each other.
