How can I check the fuel pressure?
Old Dec 31, 2005 | 10:35 AM
tiredpuppy's Avatar
tiredpuppy
Default How can I check the fuel pressure?
I have a 97 Ram, 5.9L.
I've looked over the fuel rails and lines several times and can't find any connection other
than the supply line connection on the driver's side fuel rail with it's clipped together fitting.
Do I need a special gauge with inline connections to do this?
Old Dec 31, 2005 | 11:20 AM
bamory's Avatar
bamory
Default RE: How can I check the fuel pressure?
i was looking at the manual, looks like If you are lacking a port to check pressure, there is a specific tool/testing procedure you use by using main connector. I have a port in mine from factory, but I have heard other guys on here saying they don't have any. Check out Steve's Merry Christmas post to try and download a PDF version of it. if you cant maybe I can scan my book and send it.
