Length and size of upper and lower Rad hoses please?
So I recently purchased a 1998 Ram 1500 5.9l gas 4x4 project and I want to do stainless steel radiator hoses on her, I am wondering what the lengths are for the upper hose and the lower hose? thank you in advance I am very new to this forum
Since you've recently purchased the truck, I'd recommend measuring your existing radiator hose lengths and plan to use stainless for the straight sections, unless you have some sort of mandrel bender for your stainless pipe that you plan to fabricate. You can also pull the upper and lower hoses off to measure the inside diameter of the hose. You can also find the hose specs you're looking for from the auto parts web site, too - https://www.oreillyauto.com/detail/c...ose/gat0/22083 and https://www.oreillyauto.com/detail/c...ose/gat0/22043
