Overheating
Old Jun 24, 2022 | 01:00 AM
Keith_L's Avatar
Keith_L
Originally Posted by KameronG7
Alright I burped the system and it's still running around 210-215, before it ran right at 200. I'm not sure if it's on the verge of overheating again or if it's because the engine got a lot of it's power back and it's running a little hotter. Last night it overheated and there was puddle of coolant under the truck so I thought maybe there was a leak. I've ran it today and it hasn't leaked or got in that 240 range again so I'm not sure what the issue is or was.
Well first off where are you getting your numbers? You really need a scan tool for accurate data, just eyeballing the gauge can't really tell you 200 vs 210.
Were you able to ascertain where said puddle of coolant came from? If the rad cap released due to overheating it first goes into the plastic reservoir. If it boils over too much then, yeah, it would, well...overflow the overflow. But a puddle could come from lots of places....radiator side tanks, heater hoses, weeping water pump, leaky timing cover (the latter is almost surely seeping at least a bit if you're over 150k)...and more.
Old Jun 24, 2022 | 09:00 AM
KameronG7's Avatar
KameronG7
It's the water pump, gotta replace it today
Old Jun 24, 2022 | 10:00 AM
Keith_L's Avatar
Keith_L
You really, really want to do the timing cover gasket at the same time. The amount of extra work is negligible. And once the cover is off you're staring at the timing set so there's no better time for new chain and gears. Most guys here like the double roller set and it's under $30 at RockAuto (I have no idea if a NAPA could get it or might stock it)
Old Jun 24, 2022 | 10:04 AM
Keith_L's Avatar
Keith_L
$24 plus shipping. Use a 5% code to save a bit!
Old Jun 24, 2022 | 01:21 PM
KameronG7's Avatar
KameronG7
It wasn't the water pump, it was a coolant hose I forgot to put clamps back on smh. Anyways it's still running a little hot, maybe 220ish. Could it be the failsafe thermostat making it run a little hotter? I also replaced the coolant temp sensor and can't really get a good connection on it, could it be that?
Old Jun 24, 2022 | 07:48 PM
AtomicDog's Avatar
AtomicDog
Yes to both. Do you have a laser temperature gun? If so, you can check the temperature at the thermostat housing and the coolant temperature sensor with it. If not, you can pick up one here - https://www.harborfreight.com/121-in...ter-63985.html
