Plastic nut T30 name?
Old Jul 30, 2022 | 09:04 AM
Sirriggs's Avatar
Sirriggs
Default Plastic nut T30 name?
I'm back with a question on part find. I am going to try and grease everything for the wiper motor because it seems to struggle on start. If that doesn't help, then simply replace with new motor. What I am trying to find is the plastic nut type that holds the plastic part above the motor that I would call a valance. Not real sure of it's name. One of them came off ( Don't know when) so it rubs when the wipers are moving. It takes a T30 to remove them. Its a 1999 Dodge ram 1500. Haven't had any luck searching the web to fine what it's called to do a search for the nut.
Old Jul 30, 2022 | 10:42 AM
AtomicDog's Avatar
AtomicDog
You should be able to find that part in the truck's parts manual - you can download the manual for your year truck here - https://dodgeforum.com/forum/2nd-gen...s-manuals.html
Old Jul 30, 2022 | 03:43 PM
Sirriggs's Avatar
Sirriggs
Talking
Thanks, it took me a while but now have them ordered. The heat here is crazy so didn't get out there and take off the piece that covers the wiper motor. My thinking is doing a good soaking on everything and see if that fixes the first delay when using them. Will do some touch up painting since it will be apart. Truck coming along fine so far and transmission doing better. Drove it all week to work. Down to one last part for full dash replacement. LMC dashes are on back order. Will have before and after pictures for you guys. Thanks for all the help.
Old Jul 30, 2022 | 04:51 PM
AtomicDog's Avatar
AtomicDog
Can you possibly share what the name of those plastic nuts with the T30 head are called (and the part number) and where you found them?
Old Jul 30, 2022 | 05:09 PM
Sirriggs's Avatar
Sirriggs
Actually, I think they are a T25 but yes, I found them on amazon. They run about $9 for a 30 pack. Didn't see any less.
OTUAYAUTO 30Pcs Cowl Clips 6503339 - Replacement for Dodge Jeep Plymouth Nylon Push Type Trim Retainer Clips
