Whining When Moving
Old Aug 20, 2022 | 07:25 PM
BClark_35's Avatar
BClark_35
Default Whining When Moving
My truck is currently making a whining noise when moving. Don't really have to be going fast at all. Basically just barely even moving. Makes it with the truck off and coasting. Any thoughts? It's a 2000 1500 with a 2008 rear end in it. Just swapped the rear end in a year ago with a junkyard one. Everything seemed completely fine. It's had this nosie for a while but just got a bit more noticeable the day I moved to college of course... here is a video
https://youtube.com/shorts/kPIK__zry3I?feature=share
Old Aug 21, 2022 | 08:11 AM
BClark_35's Avatar
BClark_35
Any opinions?
Old Aug 21, 2022 | 08:14 AM
Moparite's Avatar
Moparite
Is it coming from the front or the back? Did you inspect the brakes for anything dragging?
Old Aug 21, 2022 | 10:29 AM
BClark_35's Avatar
BClark_35
it's really hard to tell where it's coming from. Of course I made it to college and on the first day i get this. I'll will have to jack it up and listen when I get home. Do you think a pinion bearing could make this noise?
Old Aug 21, 2022 | 11:52 AM
Keith_L's Avatar
Keith_L
I didn't respond initially because I really don't know. My '07 F150 makes a similar noise but it's far more subtle and mostly under power so I think it's the auto trans. Never worried about it because it's done it for all 45k miles I've owned the vehicle and never gotten worse.
If yours does it coasting when the vehicle is off, that's odd. It's obviously something that spins when rolling, so axles, driveshafts or transfer case. I know that's no help but can only do so much from afar.
Old Sep 2, 2022 | 10:12 PM
95RAM360's Avatar
95RAM360
A bad u joint can exhibit the whine noise. Have you checked diff fluid level? Parking brakes dragging? Could be many things
Old Sep 9, 2022 | 12:33 PM
vince marzella's Avatar
vince marzella
Default Dodgezilla
Your spline gears need to be checked for a chipped tooth or if you have a limited slip additive in your rear end it takes 1 bottle for 3 quarts of gear oil if you have a Dana 80
