Led rear turn signals don't flash.
Old Aug 28, 2022 | 11:32 PM
Mikewhahn67's Avatar
Mikewhahn67
Default Led rear turn signals don't flash.
I recently replaced my head lights and tail light with new ones and put leds in instead of the regular bulbs that came with them. All my lights work fine but the rear turn signals. The front leds turn signals work if I put the 1157 bulbs in the tail lights but with the leds in the tail lights they won't flash. The hazards work with the leds in the front and tail. What do I need to fix this?
Old Aug 28, 2022 | 11:43 PM
crazzywolfie's Avatar
crazzywolfie
did you make sure it has an electronic flasher? electronic flashers flash the same speed with or without a load where older style flashers require a load to flash which led's don't usually have enough of
Old Aug 29, 2022 | 12:51 AM
Mikewhahn67
No it doesn't. I ordered this one just now. Hope it works. iJDMTOY (1) 3-Pin CF-13 CF13 EP34 Electronic Flasher Relay Fix Compatible With LED Turn Signal Light Bulbs https://a.co/d/7M3tzQf
