No bus and ccd 2001 Cummins 47re ATS trans
Old Aug 31, 2022 | 08:29 PM
Himter2004's Avatar
Himter2004
Default No bus and ccd 2001 Cummins 47re ATS trans
So my truck went in to limp mode and so I replaced the governor pressure solenoid transducer solenoid and the tcc and there was a connected on top of the trans I also replaced and I thought all that will fix it but it made it worse still in limp mode and I only have reverse and I went to start the truck and I got no bus and ccd no gauges work and almost all of my dash lights are on I checked all of the grounds and connectors and they all seem fine I have no idea what it is and it’s 2001 dodge 2500 cummins 47re and it has ATS trans oh and it won’t let me read any codes
Old Sep 1, 2022 | 01:43 AM
DerTruck's Avatar
DerTruck
Disconnect the plug on the side of the transmission and see if the dash comes back. If so there's a short in the wiring inside the transmission. You should still be able to drive shifting manually 1-2-3. No overdrive or TCC lockup though.
Old Sep 1, 2022 | 06:28 AM
Moparite's Avatar
Moparite
It helps to use these too...
A period is a small dot-shaped punctuation mark that is used at the end of any sentence that is intended to make a statement.
Old Sep 1, 2022 | 02:11 PM
Himter2004's Avatar
Himter2004
ok I will try that
Old Sep 1, 2022 | 09:30 PM
Himter2004's Avatar
Himter2004
ok I unplug that. but still the same. will it be the pcm?
also I do have an ATS trans controller I tried to bypass it but I don’t know if that will have anything to do with it
