Brake caliper sticking grinding inside of rotor and pulling to right when breaking
Brake calipers replaced twice with rubber brake lines issue is left caliper on the inside of the router gets grinded out breaks have been bleed from front to back and rear breaks adjusted what's the caused and due to the grinding of the the rotor truck pulls the right master cylinder replace ed and rear wheel cylinders replace as well
Last edited by Maalikcheatom; Mar 23, 2023 at 01:05 PM. Reason: Add more information
Here's a flyer: I think rotor offsets were slightly different from '94-99 and '00+ (corresponding with single piston and dual piston calipers, respectively)
Positive you have the right hard parts?
Let me check and see if I have the wright calipers thanks
Last edited by Maalikcheatom; Mar 24, 2023 at 08:17 AM. Reason: I need to check and see if I have the right parts
