LMC headlight harness upgrade
Old Mar 26, 2023 | 11:46 AM
1996snake's Avatar
1996snake
Unhappy LMC headlight harness upgrade
recently installed the "LMC TRUCK" heavy duty headlight hareness upgrade. Install was simple and easy. however I noticed two problems. with the factory foglights off, it works correcly. when I turn foglights on with low beams, the high beam indicator is dimly lite. when I switch to highbeams amd then back to low beams with forlights, the highbeams stay on. I have to turn them completely off then back on, with foglights off, for them to work high and low as they should. can't figure this out.
Old Mar 27, 2023 | 06:26 AM
Moparite's Avatar
Moparite
Sounds like it's not wired correctly. Not sure of what the "upgrade" consist of, relay i am assuming.
