47 re transmission help
Old May 25, 2023 | 04:02 PM
NICKNAME1's Avatar
NICKNAME1
Default 47 re transmission help
I couldn't figure out how to put the throttle and shift lever back on the transmission. I kind of figured it out put when I shift into gears you can not fill the shifts anymore and the idle no longer goes down and as I try to drive now there is little to no power can drive i er a crack. All I did was put in a hd valve body to help with hard shifting. Any advice
Old May 25, 2023 | 04:40 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Hope this helps.
