Pulling the TB
Old Jan 6, 2006 | 12:15 AM
SLT360's Avatar
SLT360
Default Pulling the TB
I didnt invest much time into looking at it but strait off i noticed something i have a question about. How do you pull the throttle body off with the Idler spring assembly "NO idea if thats what its called sry..". It looks like removing the four bolts and sensors is easy but to me you either have to take the cables off the assembly or remove the assembly itself. Any ideas or is my description not acurate?
Old Jan 6, 2006 | 12:26 AM
shott8283's Avatar
shott8283
Default RE: Pulling the TB
u can do both..take off the braket..i think its like 2 small screws that are a PITA.. and stip out easy..and i think they are torx too..cant remember... or the easier way..is unbolt the tb completley so you can twist and bend it around...the cables are hooked tot he cames in a special slot.. at the end of the cables is a lead knot.. the not slips off the cams a special way..when you get in there ull see and its super easy..and you really cant screw it up puting them back on... one only fits in one slot... thats the easier way...u can mark them too if you feel the need to..wouldnt hurt
Old Jan 6, 2006 | 02:38 AM
SLT360's Avatar
SLT360
Thanx , thatll be a weekend project. i tried to clean it while it was still on but i think i just managed to smear everything
