Problems with the overdrive maybe?
Old Sep 22, 2023 | 07:29 AM
jryhaugan4221's Avatar
jryhaugan4221
Default Problems with the overdrive maybe?
It only happens between 40-50 MPH and it almost feels like it’s going back and forth from 3rd gear into overdrive, also happens when I go up on an solid incline also and shakes pretty rough. I am wondering if it is a solenoid in the transmission or if the entire gear is absolutely jacked?
as always I thank you all so much for your time and effort and I hope you have a wonderful weekend
Old Sep 23, 2023 | 05:06 AM
Moparite's Avatar
Moparite
The shake is most likely an ignition issue. Replace the plugs, cap/rotor(brass terminals) and wires if needed.
